ZF 6 tranny swap auto to manual
mbaker54
Just swapped. Everything works except truck won't start??? I know electrical... Not sure what tho. Any ideas? :cursing:
mbaker54
By passed the wiring. Can't figure it out. Everything comes on to start. But won't turn over.
mbaker54
Pcm from manual. Just don't know what wires to jump... Tried all of them but still doing something wrong. Trying to find out which wires exactly to jump off the clutch pedal safety switch......
ford_trck
Vail, AZ
You have to jump 2 wires for the clutch pedal. 1 jumper is to start it and the other is so you can still have cruise control. I jumped them on mine because I was tired of replacing the switchs. I just don't remember off the top of my head which ones they were
ford_trck
Vail, AZ
If I remember right the 1st two wires go together and the 2nd two go together.
Mesa, AZ
:whs: Sounds like your starter died or you didnt hook up the batteries or somethin. Did you jump it right at the starter or did you use the inline connector up by the battery?
