zf5 with some questions
tyler2k
ok so about a year ago i put a valair clutch in for my stage 1s, about 6 months later my throwout bearing blew on me, so i replaced it. then the replacement started squealing unless you put i little pressure on the clutch pedal. fast forward to last week i dropped the trans to do bellowed up pipes and also replace the throw out again and as soon as i start it the new bearing is squealing unless you apply light pressure. so my questions are does anyone know if the bearing is always supposed to be touching the pressure plate, should i replace the fork and slave, can the fork be changed with the trans still in.
any help would be awesome
tyler2k
I did when it originally happened like a year ago basically they wanted to blame how i drive saying i can't seive stick funny cause iv never owned an auto and iv never had an issues
tyler2k
So no one knows if the throwout bearing is supposed to make constant contact and can i change the fork without dropping the trans.
