ok so about a year ago i put a valair clutch in for my stage 1s, about 6 months later my throwout bearing blew on me, so i replaced it. then the replacement started squealing unless you put i little pressure on the clutch pedal. fast forward to last week i dropped the trans to do bellowed up pipes and also replace the throw out again and as soon as i start it the new bearing is squealing unless you apply light pressure. so my questions are does anyone know if the bearing is always supposed to be touching the pressure plate, should i replace the fork and slave, can the fork be changed with the trans still in.
any help would be awesome
