Zf6 clutch help
rjustman
Had to use a tie down strap to pull it out..I didn't have a come a long so I improvised..but it came out..should be taken the t case off also..it was all off balance and ended up falling off the Jack so I pulled it off anyways..just would be been easier to pull it off first..
hey! your chit is ***ed up! wow.. lol
rjustman
The new clutch has zero noise and the clutch feels,like a Honda..is so smooth and easy to push..I'd recommend it to anyone looking for a new,clutch for sure..it's a south bend 1944-60KHD
rjustman
Thanks..so would anyone have any idea why it would work with pedal and not without..other than the obvious..i,mean does anyone have any explanation on why..
mandkole
Northwest
Did the TO bearing kill itself and get jammed? The diaphragm fingers have a heavy wear on the backside like it was jammed against the disk.
Glad it went back together ok.
