littleredstroker
Mods move if this don't belong ..
So my e99 has the zf6, 316k and I'm pretty sure syncros are shot in 2nd . Clutch to the floor , will jerk a little bit going into low and reverse, it will also grind 2nd and 4th. 1, 3, and 5 it goes into fine. As soon as you let the clutch out its engaging, like 1/2 inch from the floor. When you press the pedal in it has a good 3-4 inches of travel before disengaging the clutch..it will also pop out of second gear if I don't hold it in. question is , is there a linkage that could be wore out and if so where at? Any way to adjust the clutch or pedal or is the clutch just shot
sent while needing more cowbell
