2013 Turbo Testing MPD HTT367 Info
mario a diangelo
I just made 680 rwhp with 1427 tq
I aslo have 3 bad injectors lol found after the fact
I have the 467 fmw with dual pumps
dseitler
Royal Palm Beach, FL
If all works out over the next week I'll be swapping out my 13 pump for a 15 and still keep the H&S Dual Fuel pump. I'm not gaining only a few HP going over 2300us and if the 15 pump alone does 647 this should easily be able to push me across 700 wheel HP.
Administrator
a stock 11-14 cp4.2 and cp3 will make over 1000 .
Athens, IL
Not to derail your thread but I've been talking to Tadd about a 3794 w/68 mm billet wheel. He says spoolup should be simuliar with about 60 additional horses....What are your thoughts?? This should put me high in the 600s....
Yes it would
Sorry Gary I just can't sign off on that one. I would much rather you go with one of his Precision setups if you want to go to 600+. We tried every Tune out there with the 3794 and the 4094 and it was rough. Go with the non-VGT and Tadd knows how to Tune your truck. Tell him to send you Tune DS106 it's life changing after the 3794. Sell that 3794 to the 6.6 Duramax guys you will get all your money back and you'll be happy. Sure that's not what you want to here but I'll give it to you straight from experience.
The 68mm 2015 charger I am currently running is for all intensive purposes a 3788 modified to 68/71 or 3794 like. It runs fine as would all duramax chargers with the correct tables. I've got a ton of 11-14 3788 2015 swaps with the correct tuning that drive 100% like stock.
With the current 68mm with dual pumps and a more aggressive tune will make 48psi of boost @56 ebp.
Not needed
Yep.
Discussing you and I have had before anything over 2200 made no difference in HP with stock injectors.
it not the injectors. They flow more than a 6.4 on the flow bench. The pcm is limiting fueling... Not the injector. There is 700 available if you can get it to fuel. I have yet to drop rail with dual fuelers.
its NOT from a lack of fuel .
Yep.
around 700 is the limit on stock injectors
Give or take yes. They can flow more with more ipw, but timing needs to be added to keep the injection in the right window otherwise it just generates heat.
A 15 pump is about 1000 bucks slides right in but they are currently on back order til mid april
I have them in stock.
The 15 pumps are a good upgrade yes, but in my opinion for the ease of install, and future upgrade's, the dual fuel kit is still the way to go...........
If your goal is 650 or less it's a good option. Otherwise dual fuelers or a stroker pump.
At more than 2.5x the price. :p
Definitely not the answer for everyone.
and 2.5x the potential ;)
That's the ticket. Future upgrades!!
