Back to towing, anybody in Northern IL here?
I'm around Northern, IL.
cuz a 4x4 tractor with a loader is ***in heavy!! rear tires sould be dam near touching the beaver tail.
Generally tractors aren't as heavy as they look like they would be. I bet that 105x is under 12k with the loader unless it has weight hidden inside the wheels or loaded tires. I think that tractor is under 9k without the loader and any accessories.
17 round bales, our scale isn't finished from it's conversion from a bar scale to digital but we've weighed plenty of loads in the past.
I'd say 1,500lbs or so per bale, my truck is 10,500-11k depending on fuel in the tanks, and I'd venture to say 8k for the trailer. (44,500lb total)
My truck in the back with my trailer and 14 round bales. Farm truck up front being unloaded. My trailer is heavier then the farm trailer but less deck length. I was probably right around 41,000lb in this picture. Farm truck and load was probably 42-43,000lb. His truck is lighter then mine even with the steel bed vs my aluminum.
