Redneck, cheap dual hpop
Powersmoker
Chesapeake, Va
Nice! Looks alot like the haldex gen3 pump thats on my 7.3. Puts out way more oil than i could ever need. Ipr duty cycle cut way back even with 400/400s
Donzimama
In the Brig (Banned)
Nice work Sean, what was your setup like when you were doing 11.5s with 225s? Did you
Ever lose oil psi on them?
Redneck6.0L
When I ran 11.5's consistant that was on 205's. 225's drops to much icp and I went slower with them. Around 11.8
Fast-6.0
Alamosa, CO
I remember tadd took his dual HPOP off because he thought it was creating too much pressure and spinning the crank bearings. What do you think.
Actually at this point I feel RPM is the biggest killer of the rod bearings. I only had 30 psi of oil pressure at 5500rpm with only 1 hpop. Anything past about 4000 rpm and the 6.0 starts running low on oil pressure. We have had twin pumps live on two motors that were shifting at 4000rpm. For some strange reason I like to rev them to the moon and then they die. LOL
Redneck6.0L
Tadd if this don't work, I'll be calling ya for your dual pump setup when I save the money
6.0 six speed
Good luck Shawn! If any one can make it happen I know you will. And if not your at least gonna give it the old college try!
smokinstroker
In theory you would think it should, but its just a theory. Its not out for the 05^ trucks. The billet pump for the 03-04 is supposed to be a more reliable pump.
the hpods is out, just not the upgraded pump (for the 05+).
the hpods is just delivery lines to help flow.
Redneck6.0L
Yep and neither truck has made more power than a stock pump truck. So until proven otherwise the Riley system is nothing more than a replacement pump. NOT a high performance pump. Does the dual feed help. Show me proof that it works and then I'll but it. To this day not a single person has showed proof that Riley's stuff is a upgrade
motoxracer42
yup and you have them on one right now that seems to be working :thumbup:
