sunrisefordparts
how much for the following
Front V code: Part #2C3Z-5310-HA
Rear B code:part #3C3Z-5560-CB
Left side 3.5" tapered block: Part #F81Z-5598-FA
Right side 3.5" tapered block Part #F81Z-5598-GA
2001 Ford Excursion
2C3Z-5310-HA list $236.67 each sell $170.40 each
3C3Z-5560-CB list $520.23 each sell $374.57 each
F81Z-5598-FA list $121.33 sell $87.36
F81Z-5598-GA list $120.18 sell $86.53
shipping $100
q#397088
riverboy460
Oak Harbor, WA
Looking to upgrade my trans coolet since I hav ed to buy a new trans. Either stock 6.0 26 row or 31 row. I have a e99 f350 cclb 4x4 lariat 7.3. And yes I know it's a 6.0 collet want the mod e SD pecially since I tow heavy.
What's your price on a 4r100 trans.
sunrisefordparts
trans cooler -5C3Z 7A095-B (31 row) list =$600.75 sell =$432.54 free shipping
transmission -1C3Z 7V000-FRM list =$2835.24 sell =$2326.43 pick up only.
jban126_f350
Phoenix, MD
also need a low pressure oil pump and cover with gaskets for my 06
..possibly a rear main seal also (yes the rear on i have a front one already)
Matt_P
Lima, OH
Can I get prices on this stuff for a 6.4
2 Headgaskets
2 intake manifold gaskets
2 exhaust manifold gaskets
turbo reseal kit
2 up pipe to exhaust manifold gaskets
8 injector o ring/injection line kits
1 set of standard bore piston rings
1 set of standard size rod bearings
upper oil pan gasket
lower oil pan gasket
sunrisefordparts
2 Headgaskets
turbo reseal kit
heres your quote
  • Q398217.pdf
sunrisefordparts
rocker boxes list $1338.20 each sell $963.50 each (this is worst case as they use either 8mm or 10mm mounting bolts to the head)
g-rotor list $81.86 sell $61.88
cover/seal list $56.00 sell $33.60
rear main list $58.40 sell $42.05
q#398215
