lowered truck height
Administrator
with 4400# springs, you'll be much happier with the look , just upgrade your shocks , or it will hit the bump stops often . i trimmed mine , but it looks mucho better with 4400# vs 4800 and i have tried them all .
btoler4th
Mt. Olive, NC
Thanks Mike, always pulling through with clutch information. Just have to get my traction bar situation under control after I get her lowered. I'll give you a call next week and pick your brain on a couple of ideas I've been tossing around.
Vader's Fury
Chesapeake City, MD
Anyone tried a hydraulic bump stop?
I wanna go this route with my Excursion but want to keep the ride nice if possible.
Do they ride ok or do they ride rough with the 4400# springs
01pwrstkr
Polk County NC
I have 4400lb Springs on mine and it rides great.
Sent from my SM-N920R4 using Tapatalk
gotchadollar
I know this is awhile back thread but I'm looking to do 4400# springs and no block in the rear, anyone have the part number for the springs and the size of u-bolts I'll need?
Layin beads cashin trees.
AirFishAutomotive
DELAWARE
believe it was determined that if you do that you will have a rake in the truck, 4800's and no rear block set you up perfectly level, but here are list numbers
4,000--5C34-5310-AHB
4,400--5C34-5310-AGB
4,800--5C34-5310-AFB
5,200--5C34-5310-AEB
5,600--5C34-5310-ADB
6,000--5C34-5310-ACB
6,500--5C34-5310-ABB
7,000--5C34-5310-AAB
btoler4th
Mt. Olive, NC
Finally got this thing sitting like I want-
#4800 coils, rear block gaunt, fox 2.0 resi
After an alignment, and a solid hwy drive 2hr each way to Rudy's I am thoroughly impressed with all aspects of ride quality. I had a 4" lift and couldn't wait to really enjoy my new build with a more suitable suspension set up. Did all the work with a buddy after work each night last week. Finished her up about 1230am last Friday. Going to get some #4400 springs eventually just to see which front ride height works best for me.
Black AOD
Ohio
So I'm thinking about going low....4800 Lb Springs and no rear block. I have a 350 so I may have to pull the overload spring. My question to you lowered guys is what do you guys use for a track bar? Stock? I have an ICON track bar currently but ICON says its for 0-9" of lift so im not sure it will work. Obviously ill need new shocks as well but i can figure that out on my own...
Six_Sloww
Southeast MI
I'd try the icon bar, if it doesn't work you'll know because the axle will be off center.. From there you can do stock or Trevor at pmf has one that is adjustable for lower trucks.
4800lb springs and no block will look good on your truck.
Strokersace
Towanda, KS
What's your current tire, shock, and suspension setup?
Black AOD
Ohio
35x13.50x20 Toyo R/T
20x10 Fuel Maverick -25 offset
OUO ALA's
OUO long gusset Traction Bar with 5" Traction Block
2.5" ICON Front Springs with Icon Track Bar
Fox 2.0 Resi's
Hellwig Sway Bars
My thought was ditch the traction blocks, no rear block, pull the overload spring if I need to, get a bolt on kit from OUO (with new u bolts) with a rebuild kit for the adjuster on the traction bars, do 4800 lb front springs, new fox shocks, and try and use the ICON bar if possible. If ICON wont work ill probably get the pmf track bar
Six_Sloww
Southeast MI
4800lb springs aren't crazy low, I doubt it'll shift your axle too much.. I never noticed my 6.0 axle shifted with a cut 4400 lb spring and the stock track bar
madman1234509
mayfield, ny
Stock track bar here. Only issue we have had with anything is when we recently put my flight fab 4 link on. It moved the axle forward maybe an inch or so ato it's shortest adjustment. Molded the 4 link, no issues. Saw a lowered truck at rudys with the same 4 link, front axle was slightly forward like how mine would have been.
akf250
I am very tired of bouncing off the bump stops, shock upgrades just don't do it, and I believe this is the answer.
Does anyone have pictures of a lowered 6.4 with frenched in hydro bump stops?
Cant you just buy weld on frame rail mounts and get a longer bump stop?
Black AOD
Ohio
Shane aka WhiteMonster is about to do this on his f350 6.4. Although he runs stock spring front and a 2" rear block on king shocks. I believe his air bump stops are King as well that he will be doing.
