madman1234509
4400 lbs you'll need to trim the bump stops as you'll most likely be riding on them. 4800lbs you won't actually ride on them
with 4400# springs, you'll be much happier with the look , just upgrade your shocks , or it will hit the bump stops often . i trimmed mine , but it looks mucho better with 4400# vs 4800 and i have tried them all .
I have 4400lb Springs on mine and it rides great.Anyone tried a hydraulic bump stop?
I wanna go this route with my Excursion but want to keep the ride nice if possible.
Do they ride ok or do they ride rough with the 4400# springs
I know this is awhile back thread but I'm looking to do 4400# springs and no block in the rear, anyone have the part number for the springs and the size of u-bolts I'll need?
Layin beads cashin trees.
So I'm thinking about going low....4800 Lb Springs and no rear block. I have a 350 so I may have to pull the overload spring. My question to you lowered guys is what do you guys use for a track bar? Stock? I have an ICON track bar currently but ICON says its for 0-9" of lift so im not sure it will work. Obviously ill need new shocks as well but i can figure that out on my own...
What's your current tire, shock, and suspension setup?So I'm thinking about going low....4800 Lb Springs and no rear block. I have a 350 so I may have to pull the overload spring. My question to you lowered guys is what do you guys use for a track bar? Stock? I have an ICON track bar currently but ICON says its for 0-9" of lift so im not sure it will work. Obviously ill need new shocks as well but i can figure that out on my own...
I am very tired of bouncing off the bump stops, shock upgrades just don't do it, and I believe this is the answer.
Does anyone have pictures of a lowered 6.4 with frenched in hydro bump stops?
Cant you just buy weld on frame rail mounts and get a longer bump stop?
