woodsman
Can I please get a price on:
ITEM 2 - 2009 F-350 Super Duty XLT Right Upper molding 8 FOOT BOX, BODY SIDE, black
ITEM 2 - 2009 F-350 Super Duty XLT Left Upper molding 8 FOOT BOX, BODY SIDE, black
ITEM 1 - 2009 F-350 Super Duty XLT Tail gate mldg 8 FOOT BOX, TAIL GATE, w/o tailgate step,
Shipped to 98223.
Thanks!
sunrisefordparts
Shipped to 98223.
Thanks!
are these the bed moldings and tailgate molding?
NY_Mott
The Real "OC" NY
Just wanted to say thanks for what you all do...
quick quote, called to place my order; was promptly sent a paypal invoice which imedieditly paid and received a tracking number shortly after...
This is the 3rd order iv placed and I am once again completely satisfied.
Thanks again...
sunrisefordparts
Thanks again...
not a problem, we thank you guys for coming back and giving us the advantage to make it pleasant to spend money.
Str8Ugly
Odessa Tx
Vin: 1ft8w3bt1bec67454
Front Passenger side abs pigtail that's in the factory harness and next day shipping
sunrisefordparts
that should be a 2 pin connector right? the catalog is calling is the wheel speed sensor pigtail so just trying to make sure its only a 2 pin
pigtail list $54.32 sell $39.11
overnight ups about $17
Str8Ugly
Odessa Tx
Yes it's a 2 pin connector, if my dealer doesn't have I'll get it from you
Can you get black seatbrlts for a 2000 crewcab. I dyed mine and they look like crap.
sunrisefordparts
They didnt but i thought the pn would be the same.
the only differences is the part numbers use the sequence based by the year. could be a difference of the connector for the pretensioner or something so small as the mounting bolt being a different diameter.
Lugger007
Ct
Is the wiring harness for roof clearance lights available? also is the plug/pig tail that goes into the clearance light available separately ?
2012 f250 Thank you
Rob D
Massachusetts
2001 F350 4x4
Need:
(2) axle seals - F81Z-3254-CB
(2) dust seals - F81Z-1S175-HCA - unless the new style dust seal would work but I believe those are only for 05+ trucks?
(2) hub yellow o-ring - F81Z-4A322-AA
Trying to decide if I am going to stick with Ford factory auto hubs or switch out over to Warn manual locks. Putting all new seals on the truck so feel like I mind as well stick with factory setup...Please quote me for:
(2) new auto hubs
New vacuum hosing from the hub to the first connector for both sides - does Ford even offer just these lower sections or is it a whole kit from the pump down?
Thanks!
UNBROKEN
Pricing please on a tri-coat white tailgate handle for a 2014 F150 and also
tri-coat white rear driver and passenger side door handles for a 2015 F250.
I'm trying to de-Platinum my handles.
If you need VIN #'s just lemme know...I can provide pretty easily.
