Single cab street truck build
thewrubelator
The Dirty Glove
Anyone have pics of a JGS 50mm gate on a single turbo setup? Trying to figure out the best route to take for mounting it and plumbing it through the hood. As of right now, probably run of the passenger side up-pipe, have it sit between the downpipe and uppipes, with 2" coming off the gate, under the the turbo along the passenger side Intake mani, a 90* up at a slight angle to clear the hot side pipe and up through the hood. Let's see what you guys have. Lol
thewrubelator
The Dirty Glove
Made some progress last night. Hopefully have it stuffed by next week.
thewrubelator
The Dirty Glove
Got the bottom end together tonite. Putting front and rear cover on, upper and lower pan, pick-up, and lifters in tmrw after they are finished soaking. IMG_5741.JPGIMG_5742.JPGIMG_5743.JPG
thewrubelator
The Dirty Glove
Just an update, upper and lower oil pans on, front and rear cover on, lifters and hold downs on, along with HPO Branch tubes. HPOP, oil cooler, and filter housing going on today along with the front and rear cover wear rings pressed in.
Oroville, CA
swinky
Eastern, Nc
This thread is boring I'm going to go catch Pokemon in the middle of the street.
Sent from my SM-N920P using Tapatalk
thewrubelator
The Dirty Glove
Made progress. Heads are on and torqued, exhaust manifolds are on. Intake mani, flexplate, injectors, and valve covers going on in the am, then putting the motor in. Should be running Friday night/Saturday morning! IMG_5804.JPGIMG_5805.JPGIMG_5806.JPGIMG_5809.JPGIMG_5811.JPG
Nick7.3
Nice man.. Maybe you can take me for a test ride when your passing through lol
thewrubelator
The Dirty Glove
Sorry, moved from California to Michigan this past weekend, so have been handling that. Truck ran great cross-country towing a 6x12 uhaul. No problems, ran smooth even going up big grades. Can complain at all!IMG_5921.JPG
there looks to be something missing from the front of the truck? :poke:
