Wheel/Tire Tech Thread
Cantbuytime
2008 F350. 2" leveling blocks upfront. Truck sits 1/4 inch higher upfront then the rear. 35x12.50x18 Coopers on factory 18" Alcoas. No rubbing.. Fuel mileage suffered horribly after this setup was put on. About to remove the front blocks and swap front Springs. Then remove the 3.75" blocks out back. Gonna bring it down , run some factory 20s and a 295/50r20 LT's or 305/50r20 LT's.
Sideswipe505
New Mexico
Can anyone help me ID these wheels? I think they're off an '11 but I'm not sure. They came on my '08 when I bought it.
those are factory 11+ wheels. came on lariats with heavy tow package.
Redvtwin2
325/50/22 on 22x12 v-rock wheels (6" Lift)
Sent from my SM-G930T using Tapatalk
Black AOD
Ohio
Threw the SF wheels on the ole 6.4 to go out to UCC.....SF-023 22x12 (-44) on 325/50 Nitto G2 Terra's. Truck is 350 stock height rear with ICON 2.5" leveling Springs in the front.
They do rub. I'll be trimming the back of my inner fender and spacing out my front bumper just a tiny bit and that will take care of it.
Black AOD
Ohio
No he didn't. Those are brand new
Yeah these are the SF-023 Mike (BigR) was selling...I snagged these a few months back.
I don't know who bought the SF-009 that were on here. Whoever did got the best deal of a lifetime though.
2stangs8689
Lockport, NY
OK, now that I have a headache from offset and backspacing......if I run a 18x9 Fuel Hostage, with a -12mm offset and 4.5bs, with a BFG TA/KO2 325/65/18 tire, on my 2005 F250 with a 2.5" leveling kit....... will it rub, and how far out of the well will it stick out??
I'm going to add fender flares, and I'd like the combo to basically be flush with the flare.
Thanks for the help.
Brian22
Forney, Tx
I'm running 20x9 -12 with 35x12.50's on a 2" level. I had to trim the fender liners just a bit. It would only rub at full lock turning into my driveway. It sticks out about 2" on each side.
2stangs8689
Lockport, NY
Thanks for the reply Brian. It seems that the older trucks run a different offset I believe than the newer trucks. Sweet ride tho!!
Brian22
Forney, Tx
I'm pretty sure the 05 trucks have the same offset as the 11-16. It is the 04 and older trucks that are significantly different.
