800+ HP 2008 F350 For Sale
Status
Not open for further replies.
Black AOD
Ohio
Bump! nobody likes it apparently. It's all Jomax's fault.
Keeping the SF wheels now since no one was interested apparently in them on the truck. Still $35k. Will come on my old fuel 20x10 Maverick Black /Milled two tone wheels on 35x13.50 Toyo R/T tires
300000 and counting
Ohio
Is this the only place you have it for sale?
I guess it's all my fault LOL.
Black AOD
Ohio
Bump.
Including the SF Wheels again to come on the truck...someone make an offer. $32, 500
Bump for a crewcab.
C2tuck
North Texas
Thanks Man. If it doesnt sell by the time summer really hits I'm keeping it, paying off the little that's owed and it's going on a serious diet and I'm going to add more fuel /air and try to make a 10.5 index truck.
What happened to this^^
Life happened and the truck isn't priority anymore.
I don't blame you. I stopped myself from doing more then a tune.
Black AOD
Ohio
Yep.
There is a small possibility that if I can't sell it by end of year, I'll keep it (because I'd rather keep it than give it away) and pull out the motor, open it up, refresh whatever needs refreshed and put billet rods in it, port the heads and do bigger intake/exhaust valves, put an Odawgs Diesel Intake Manifold on it plumbed for 2 stages of spray, billet lpop gears and line bore the block for main studs and put it all back together.
Put it back together with the same fuel system and turbos. The nitrous will actually put the 100% injectors to good use and I can lower the truck down with no rear block and 4800 lb front springs on street tires. Should be a solid 875-900 on Fuel and 1000+ easy on spray. Lose some weight and I could probably get it to low 11's.
But I would rather it just sell tbh lol
Yep.
That sounds like a lot of money lol. But if you lower it, do 4400lb front springs.
Status
