webb06
Took my 6.4 to the track for the first time tonight since I've had it together. On the initial test drive before the track it seemed to spool good and take off like a rocket. Get to the track the first pass I spooled to 2200rpm not sure what boost and only went 14.5 @ 94. Got back to the pits and got it to spool to 2800rpm and 16psi which seemed like it would be promising. Get to the line and it wouldn't spool passed 2200, i had messed with with wastegste thinking it was blowing open before this pass, but on this pass I have a video where I can see it blowing the gate open then halfway down the track it takes off and click 13.06 @ 111. ******** tuning with MAF zip tied to the turbo screen. Not sure if the sensor needs mounted in a tube to get a good reading? MAF reading 28-30 at idle, which I don't think is right.
Need a little guidance. New to single turbo.
