sunrisefordparts
Sean,
Wanted to check in and see the status of a wiring harness from a order I placed in July. The order number was 1634.
Thanks
Kris
Hi Kris,
It is still on national back order with no ETA.... Do you want to leave it on order?
sorry,
Sean
brewer
Hi, looking for a right strut mount for a 2013 Explorer (Build Date of 3/2012). Looks to be part AD-1084 (BB5Z-18183-A), please confirm and provide a quote.
Thanks,
Brenden
kleake
Sapulpa, OK
Need price for low fuel pressure sensor on a 2014 Fusion SE 2.5L
I think the PN is BM5Z-9F972-A, but please confirm as I have seen some searches say that's not the right one.
Thanks
sunrisefordparts
Thanks,
Brenden
Hey Brenden,
list price on it is $64.73 -- your cost would be $39.16 + shipping, in stock.
thanks,
Sean
Q628747
sunrisefordparts
Thanks
Hi,
BM5Z-9F972-A is incorrect, it is the fuel rail pressure sensor for the ecoboost motors. I believe the one you are looking for is DG9Z-9D683-E, list price $95.84 -- your cost $57.98 + shipping. The sensor is serviced with the vapor tube that attaches to the tank. I would have to order it in, 1-2 days lead time.
thanks,
Sean
Q628749
kleake
Sapulpa, OK
Hi,
thanks,
Sean
Q628749
hmm, definitely a tricky one to locate the right p/n. Just to be clear, it isn't the sensor for when I am low on fuel, I am needing the low fuel pressure sensor on the fuel line. My understanding is there are two fuel pressure sensors, one on the fuel line near the brake master cyl, and another on the fuel rail. Fuel rail is high pressure sensor, the other is the low pressure sensor. Effectively it is stumbling and dying at low rpm occasionally and everything is pointing to this low pressure sensor but the exact PN for the non-ecoboost version doesn't always show the same number depending on where I look. Is this the correct one you are referring to?
sunrisefordparts
I did some more checking, the one I quoted is the fuel tank pressure sensor... There is also one in the fuel line as well, but there is a prod date split. Can I get the last 8 digits of the vin?
thanks,
Sean
sunrisefordparts
Last 8 of the VIN: ER143927
It is going to be serviced with the fuel line bundle (see attachment) DG9Z-9J279-QH List price $260.73 -- your cost $172.08 + shipping. Figure at least 2-3 days to reach us, then at least the same to you....
thanks,
Sean
Q628749
sunrisefordparts
thanks,
Sean
Q628749
here is attachment... lol
kleake
Sapulpa, OK
thanks,
Sean
Q628749
Yikes!!!! I was hoping it was just the sensor for $50-$60ish. Ok, I may try a few other things before I commit to replacing that. Thank you.
sunrisefordparts
That looks like just a line set? I also found a closeup pic from someone selling one on ebay and I don't see any sensor on it, just the lines. I hate to keep poking at this, but are we sure that has the pressure sensor?
Yep, Ford has a note in the catalog that says "includes low pressure sensor" and does not list it separate.
sunrisefordparts
Front valence(4x4 type) for a 2012 shipped to 77573. I think the p/n is BC3Z17626BA. Thanks
Hi,
your cost on the valance would be $116.09 ($131.93 retail) Unfortunately due to the size of the box shipping is crazy.... $248.00
sorry,
Sean
MorganM
SE Houston
Hi,
sorry,
Sean
Thanks Sean- appreciate the quick response. I think I was able to find it locally for near the same price. Or I’m getting cheated. We’ll see. Thanks again
