Ford 7.3 Passenger Bank Dead
NitroJoe
Ft. Lauderdale, FL
Story behind truck – I bought it as a crank no start and got it to this point. IDM was fried, injectors blown out. 2000 Ford Excursion 7.3 4x2 with 276K miles.
Rough start, dead passenger bank. Manifold is cold.
FFD Stage 1 injectors installed.
No codes in PCM or IDM, injectors all pass buzz test. All Injectors squirting oil from deflector when running. No visible high-volume leaks. LPOP reservoir filled to top.
IDM Harness Ohm’d out to all injectors and GP at 2.9 Ohm. IDM is new unit from DTC.
Main harness removed multiple times and continuity, and OHM checked, all pass.
Both driver and passenger UVCH changed. Connectors verified on both sides.
Driver VC checked for abrasions on wiring, none found, put heater hose on the wires anyway.
Checked Oil pressure at rails, >2000 idling on both sides with high pressure mechanical gauge.
Fuel filter showing 60 PSI pre.
Removed passenger check valve, was a little sticky so removed it. Blew out line towards the filter to verify its good.
No fuel in coolant, No Fuel in Oil, fluid levels remain the same for both.
I also swapped in a known good IPR, same ‘no fire on passenger’ condition.
When valve covers were on, I did the flip the oil cap upside down and it just vibrated, not a lot of pressure.
I don’t know where to go from here. Any help is appreciated.
I have used search, watched videos, etc. But here I am.
Thank you, Joe
DEEZUZ
NO PUKESTERS
NWI
You removed/cleaned the filter screen on the cylinder head? You can remove the opposite end casting plug to make sure fuel is flowing through the head.
NitroJoe
Ft. Lauderdale, FL
Yes on the line behind the pass head next to turbo, I removed the check valve and gutted it. Then blew out the line back towards fuel filter. When I removed the line, very little diesel came out. I expected the head to drain.
On the passenger head how do I do this? Is it behind the AC compressor and idler bracket? I have not found any 1/8 plug so far, but I did not remove the accessory drive.
Thanks.
DEEZUZ
NO PUKESTERS
NWI
Oh it's buried deep down in there.. I was able to get mine out without taking the accessories off. That was when I installed my Riffraff FRX. Its just a typical square head pipe fitting
NitroJoe
Ft. Lauderdale, FL
Thank you for the suggestion. I didn't see it under all the gook.
Once I cleaned the area and hooked up a pressure gauge it showed 100 PSI on prime and then backed down to 65 after prime.
Any other ideas? I have read about IDM shutting down banks at a time, but usually with an accompanying code or something. The likelyhood of 4 cylinders with bad compression is also low. Even a bad injector copper seal wouldn't prevent the whole bank from firing.
-Joe
DEEZUZ
NO PUKESTERS
NWI
This thing actually runs/idles with only left bank firing?
Mesa, AZ
Thank you, Joe
Check power on the engine harness to that bank. Believe it’s the center pin at the valve cover gasket.
NitroJoe
Ft. Lauderdale, FL
Ok, I will. It does pass all buzz tests both audible and no codes on PCM and IDM. Buzz test should indicate power is working and the IDM, right? The IDM harness checks all show 2.9 ohms through inj.
I'll have to get back to you tomorrow after work.
DEEZUZ
NO PUKESTERS
NWI
Not necessarily. Everybody's buzz test is not the same.
Does it sound like this
NitroJoe
Ft. Lauderdale, FL
It's way louder than the old injectors. That video seems really loud. Mine are not that loud.
The injectors are a consistent volume across all 8, no dips, or weak pulses.
DEEZUZ
NO PUKESTERS
NWI
I wonder if your bein fooled by buzzing and not actual injector actuation.. Grab a video/sound profile
Mesa, AZ
In theory a buzz would indicate that it’s working. However there is something that buzzes during the test that is not the injectors. I’ve had one bank unplugged unknowingly and the buzz sounded ok, not great, but it threw the bank 1 hi to low failure code.
2.9 ohms is high if you’re homing just the harness, can’t remember the injector coil side spec to tell you if that’s good thru the injector coil side or not. But you could have a failed splice somewhere that isn’t sending power to the injectors.
If the whole bank is dead, it’s either a valve cover gasket connection, be it internal or external, a single failed injector killing the bank, or wiring. Most likely with wiring would be the power, as it’s a common power, and idm ground controlled for actuation. The chance of having 4 bad wires is much less than 1 bad wire.
DEEZUZ
NO PUKESTERS
NWI
I suspect he's getting the low roar of the events but not actual poppet actuation, which is the loud clap.
NitroJoe
Ft. Lauderdale, FL
Captains Log - Monday
No Codes in PCM or IDM
Voltage on center pin for both harnesses is 4v-10v (which is in range for the 100+volts)
Audio file recorded but site will not let me attach. Buzz test is clean and clear.
Also attached Autel outputs for the normal sensors.
Additionally, I turned over the motor by tripping the starter to see if I would get bubbles through my pressure relief on my gauge (to check for bad copper seal) - no bubbles
I have exhausted darn near everything. I think it may be time for a compression check. Anyone know if the harbor freight kits works out of the box or will I also need that glow plug adapter?
NitroJoe
Ft. Lauderdale, FL
The 2.9 is the result from the IDM connector in the fender well through the injector and back. According to the test page that is an acceptable range. But let me know if that is not right.
I hear you on the wiring, but I have removed and tested this entire harness 3 times, both for continuity and OHM. I have also unplugged each brand-new injector 1,3,5,7 with no change. What are the chances I got a bad Full Force injector *4? I have physically un-loomed the entire harness and checked everything -- even separating out the injector wires in a separate loom to prevent any induction.
This is supposed to be the easiest motor to work on, lol. I'm 6 weeks into this issue.
Powerstroke Cowboy
Montana
Have you tried swaping the UVCH from the working bank to the non working bank?
The chances of getting four bad injectors is slim, but getting all four in the same bank is even slimmer.
Do you have a known good PCM and IDM you could swap in? I know you said the IDM is new/remand.
Check to make sure there's no chip plugged into the PCM.
Sounds like you have a real head scatcher here.
As the others have said, a clip of the injector buzz test would be great. If you need help getting it loaded give a shout. Also, do you have a clip of the engine running?
NitroJoe
Ft. Lauderdale, FL
Yes, I have a clip of the buzz test and engine running. Sugestions on how to post and I will get it loaded. Looks like I have to use a third party to host those files.
As to the IDM and PCM. IDM is 'new' from Diesel Tech of Chattanoga, but I sourced another one (used) and it will be here Fri.
PCM Is the same one that came with truck. Do not have another to test with. Hydra chip is REQUIRED because Full Force Diesel injectors are single shot instead of split and programming adjusts that. FFD states do not run without chip.
Both UVCH are brand new and were ohmed our prior to install. I can swap them if you wish.
Powerstroke Cowboy
Montana
Yes, third party platform is needed to upload a video.
The engine will start and run without the chip. It just will not run as good as it could do to timing differences between split and single shot tuning.
As you know, at this point you have to start playing the game of process of elimination.
