installing my injectors....
Derek@Vision Diesel
Canby, OR
They are swamps 175/30s. Best way I can explain it, if feels and sounds like its misfiring on take off, its chugs
If you dont have access to a scanner just take 20 minutes and pull the valve covers off. Then fire up the truck, first watch to make sure each one is spitting a decent amount of oil out the deflector, then start unplugging each injector one by one. If you find one that does NOT affect the idle like the other ones do, you've found a source of a problem.
This will also give you a chance to throw the straight edge on it again, just to double check.
Unfortunately you cant try it without a chip since you went to singles. I would tell Matt about your issues if you dont find anything, could be something in the tuning
SouthFlstrokin'
Gonna replace the fuel fitlers now. I don't think it will solve the chugging issue though.
The fresh oil did make it idle MUCH better . Hopefully this weekend ill get a hold of a scanner for it
Derek@Vision Diesel
Canby, OR
Hmm maybe your IDM is getting ready to take a dump.... that could cause some of the issues youve been having. Sometimes cylinder faults dont always mean anything.... you could scan it multiple times and see multiple different cylinder faults
SouthFlstrokin'
That would explain why when I previously scanned it I had a cyl #8 fault.
Kinda weird I beleive at idle my icp was only around 400 too if I remember correctly
SouthFlstrokin'
This makes me wonder if I have a hpo leak. I guess ill tackle one thing at a time. First off is to get a new idm
