Hotrodtractor
OK guys - I bought this a couple of years ago - it is a common rail 4BT otherwise known as an ISB170 - it is 170hp right out of the box before you start tinkering with it - making it an awesome candidate for a daily driver fuel sipper engine conversion. It has a 5 speed Allison 1000 with it, all the wiring (integrated together) computers, IC, radiator, transcooler, some IC plumbing, a new in box alternator, wiring diagrams, the works. The only thing I know it doesn't have is the throttle pedal.
The awesome thing about this setup is its BRAND NEW - but old stock. This was installed into a Workhorse step van chassis that NEVER received a body - it was used in the service department for training and troubleshooting - it has a few hours of run time on it, but other than that it has never been used.
I know there is an exhaust manifold bolt that is broken and a coolant sensor that is broken from shuffling this around the shop at its previous home before it came here. I purchased it for a project vehicle and I had some issues with the actual vehicle early on during tear down that caused me to stop working on it - now I'd like to clean up the shop some and do some expansion and improvements to my facilities.
Located in Central Ohio - Could be delivered to the NHRDA World Finals in Ennis, TX in October 2012. $7500
I can get some better pictures if someone is serious - its kind of tucked away in the shop under some shelving at the moment. Feel free to ask any questions.
