2005 F350 Cab & Chassis Dana 80 Rear axle
BCB
I have a running and driving Dually cab and chassis truck that i am converting to a single rear wheel truck. The only issue with this axle is the right side wheel seal started leaking about 100 miles ago. I can replace this seal for the price of the seal on request. Other then that there is no known issues with the axle. 4.10 gears.
I'd like to get 550 out of it but would really rather just trade it for a SRW 10.5 Axle out of a 05-07 truck. I can deliver it up to 200 miles at $1.50/ mile
dam, i need a d80... i have a 10.5 to trade, whats the difference in 10.5s from 01 to 07? will a cab and chassi rear be any narrower or anything from a normal truck?
STROKED_NY_023
Also interested... Location??? As asked above with it being a C&C truck is the frame narrower in the rear?? What kind of milage does it have? VERY interested, i have a 08' srw 10.5 with 4.10's and 3k on it.
1ofakind79
Herminie PA
A C&C axle is narrower than a pickup. around 6" overall. The spring perches are wrong also. the C&C trucks have a narrower from therefore the perches are in. They can't be moved out because of the brakes. Also 05+ trucks have a 8 on 200mm pattern and require 17" wheels 99-04 is 8 0n 170mm and 16" wheels
STROKED_NY_023
I knew that to be true with the 04 and older trucks, thanks for confirming on the 05+.
