Tow mirrors for OBS'S?
rat49f6
Vernon,NJ
I finally got some time to put some bondo in the welds and cover up the bear metal. I used white plasti dip for right now until I can get it warm enough to actually paint the door.
Could u post a pic with the wing window open as far as possible? Front and back view
Sent from my SGH-T889 using Xparent Green Tapatalk 2
smcox1
Wow!! That's awesome. Did you just tint the orange visor lights?
smcox1
Thanks I stopped to get some today and the parts store didn't have any so instead I got some red vht tint for my led tail lights...
smcox1
I was looking at my truck and I want to put some dmax mirrors on it and was wondering why the bracket that is welded to the truck couldn't be dropped down to the body line (2" lower then where its at now) and moved forward towards the front of the truck a couple of inches? Wouldn't that leave the wing window completly functional? Also you wouldn't have to look at the bolts through the window.
smcox1
So I'm thinking something like this. With the 88-9? chevy tow mirrors
bucklee00
Put these on a while ago. They are eBay Chevy 88-98 tow mirrors that bolt on same as the dodge tow mirrors, with a triangulated 3 hole mount. Hole in the center is for the wires.
Cardboard mock up.
Steel bent to match the cardboard with rear lip for decreased vibration
comparison
bucklee00
Vent windows can still open 70% of the way.
The mirrors vibrate a little more than I had hoped for at 80+, but they are a lot better than stock. I hardly even use the top mirror unless pulling a long trailer. The bottom mirrors are fish eyed, and they're what I like to use because you can see everything beside and slightly behind the truck. Also, with the mirrors in, you can still see all of the passenger side mirror. (I was worried about the vent window bar blocking it)
Here is how I trimmed the new terminals to fit into the old socket.
Power mirror wiring
Passenger:
Purple to yellow
Green to blue
Yellow to green
Black to white
Driver:
Yellow To green
Y Ti white
Blue to yellow
Red to blue
wildbillcody97
Seaford, De
I have a set I'd 03 SD mirrors but the body shop guy I went to (didn't really think much of him sounded like he just didn't want to do it) said it would be to stressful on the doors to replace the vent windows with a welded in plate to bolt the mirrors to. What is your opinions?
Sent from my DROID RAZR HD using Tapatalk
