97 single cab dually build. My DD
jwlandry
S.W. Louisiana
Traction bars are on. I never would have guessed the difference that they could/did make. Truck handles so much better.
jwlandry
S.W. Louisiana
My clutch is very grabby and would make it shudder when I would take off in second.. That is now gone. When you stab it, it just goes not sit down then go like before. Ride quality hasn't changed. It's still rough.
Powerstroke Cowboy
Montana
This information I like. Sounds like what mine does at lower rpms in the lower gears. I might have to build a set sooner then planned.
jwlandry
S.W. Louisiana
i know. Ive been just enjoying it. Since i had done injectors i wasnt thrilled about the way it ran and drove. Now since doing the t4 mount and 366 i couldnt be happier so its been getting put through its paces.
jwlandry
S.W. Louisiana
Im also gonna try and do a '12 rear leaf spring swap. I already have some PMF brackets i was going to use on my superduty before i sold it and never got around to doing the swap so i figure might as well try em on here.
Strokersace
Towanda, KS
Do it!! I put B code rears in ours with velvet ride shackles. What a difference that made. I'd bet the newer ones would be even better.
Dmstrucks02
Pearland, TX
I was going to text you about those Springs...
Sent from my SAMSUNG-SGH-I537 using Tapatalk
jwlandry
S.W. Louisiana
If they dont work ill let you know. I spoke with Trevor and they have never been done on a OBS so we shall see. I dont see why they wouldnt work though honestly.
Got Smoke?
Ok I've heard of the B code swap, but that plus velvet ride shackles in a OBS? Interesting... I'm waiting on a local who's parting out a SD to get the springs out for me I'm in desperate need of a better ride.
Strokersace
Towanda, KS
It made ha HUGE difference even from the velvet rides and stock OBS rear springs. Very pleased with the ride.
