Dan
Call he shop tomorrow & ask Devin about getting the kit Dan has on the race truck. He can explain it better too.
-Amy
Ok thank you!
-Amy
Also... I don't have the engine in front of me right now, where do you guys suggest tying into for oil pressure sensor?
is the factory sensor gone?
I tied mine in right into the factory oil temperature sensor by the filter housing... Does that make sense?.. Here's a pic
Be warned.T'd into the temperature port will throw the oil temps way off. Put it on the opposite pressure side.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Tying into the factory oil temp sending unit location for your additional pressure sensor will result in the factory temperature sensor reading out lower than being in its stock location.
Between the "T" used to tie into the system dissipating heat, and moving the factory temp sensor away from the direct flow of oil inside the filter housing, temps will read out lower. 20 degrees lower give or take a few degrees.
So I don't mess with the temp sensor!! Is there a different spot I can tie into?
Not to muck up your thread Dan but just thought I'd inform the guys that read this. I noticed my oil filter leaking the other day. Figured it was just a little bit loose. It was tight and I noticed the oil coming out of the seam of the filter at the top. I don't know if it's just a bad filter or what. Sad part is its only been on for 1000 miles. And it's the Motorcraft filter.
Sent from a lawn mower
Your all good! I noticed that it'll leak a bit but you tighten it down real tight and then wipe up the excess oil once and it does good after that... I might be way out too lunch too! Haha
In other news: switches!
I swear this is the cleanest I've seen this truck! Haha
Kinda
And here's our variation of what kaleb so kindly shared!
Also there's a bov controller in there somewhere!
That a pillar was sweet until you raped it with an arp sticker. Switches are awesome tho
