zilla68
Moore Oklahoma
heres the spring quote. bumper is only available in chrome with the cut outs. list $540.38 sell $389.08 shipping $15, shipping for springs is $50 for the pair.
can you change the shackles to rear shackles for my 96, and do they come with bushings installed?
do you know if the leaf spring bolts are the same on the 96 and the 99-03?
sunrisefordparts
the rear spring bolts through shackle to hanger and shackle to spring are a 14mm bolt on the obs, on the 99-04 they are a 16mm bolt through the shackle to spring. the shackle for your 96 list $59.37 each sell $42.74 each
sunrisefordparts
front and rear rotors and pads for a 2005 excursion diesel 4x4
front pads list $116.63 sell $83.98
front rotors list $124.97 each sell $89.98 each
rear pads list $83.30 sell $59.98
rotors list $133.30 each sell $95.98 each
shipping $15
q#317931
acf6
Manchester, CT
Really random request and im not sure how well I can describe it but... 2003 F350 6.0 crew cab king ranch auto trans non adjustable pedals... the harness that goes above the turbo across the cowl to map and maf sensor and inside to the throttle pedal and baro sensor, etc...
sunrisefordparts
are you looking for the harness or just the shield around it?
Taylor D
Sebring, Florida
08 f 350 srw regular cab 6.4
Need glow plugs, middle and rear body mounts and egr pipe the one that connects to up pipe up top then goes down and connects to egr cooler also need all hardware for this pipe
Sent from my LG-LS980 using Tapatalk
TD-5
British Columbia Canada
Looking for Part# & price on the grommet type seals for the rocker cover bolts & studs on a 2010 6.4 powerstroke.. These are the seals for HB1 & HB2 in the attached drawing, or as indicated by the arrow in the attached picture.
Thanks
zilla68
Moore Oklahoma
are the bolts the same thread?
do you have a blow up diagram of the rear end sway bar? I can see
