front pads list $116.63 sell $83.98
front rotors list $124.97 each sell $89.98 each
rear pads list $83.30 sell $59.98
rotors list $133.30 each sell $95.98 each
shipping $15
q#317931
im assuming since its an eddie baurer that it has heated seats, either way they are priced the same
driver pad list $127.78 sell $92.00
passenger list $127.78 sell $92.00
free shipping
q#313566
ordered-thanks.
sunrisefordparts
2003 6.0 Powerstroke:
-Complete set of valve cover bolts for the drivers side valve cover
-Turbo oil feed line gasket
-Turbo oil drain line o-rings
-9T288 HPOP discharge line and or O-ring where it connects to the branch tubes
usps tracking #9114901159818696689818
sunrisefordparts
Thanks
Hey what does it take to convert my 08 f350 2 door xl to power windows and locks?
Already found tan power door panels with switches
Sent from my SM-G900P using Tapatalk
it would be a fun time of getting harness', regulators w/motors, door lock actuators, and switches, or you can just get needed pigtails and wire it yourself.
Taylor D
Sebring, Florida
What's the best/ easiest way to do it and when u say harness is this an additional harness or completely new truck harness remove old replace with new?
zilla68
Moore Oklahoma
Rear Hub Seals - #2C3Z-1177-AB (Qty 2)
- Axle Shaft O-Rings - #E5TZ-4A331-A (Qty 2: Thanks to Guzzle for this one)
- Oil Slinger (I Broke Mine) - #F81Z-4670-AA (Qty 1: One per side; May Vary with model year)
- Inner Bearing - # F81Z1244AB (Qty 2: Cone Only Does NOT Include Cup, and please double check this Ford Part Number); Also TIMKEN# NP114036 09719 USA YZ081Z
- Outer Bearing - # C7TZ-1240-A (Qty 2: Cone Only Does NOT Include Cup); Also TIMKEN# LM104949 778 08 YT
- Inner Bearing Race - #NP064306 (Qty 2) Sourced from NAPA
- Outer Bearing Race - #LM104911 (Qty 2) Sourced from NAPA
10 ford wheel studs also
this was a copy and paste, but do these part numbers match up to a 96 f350 rear end also?
sunrisefordparts
if the truck isnt equipped with power to the doors then going the factory route would be have to replace harness' all over. if you went pigtails and ran your own power source then it would work out better just some good work for ya, luckily is only 2 doors.
ups tracking for the springs 1Z5775X90399045309
Taylor D
Sebring, Florida
Okay shoot me a price with everything to go the pigtails with my own power source way.
ToMang07
Mainah!
For shats and giggles...
For a 2004 F-150 4x4 CC Lariat w/ 5.4L/auto:
Wheel Speed Sensors (LF+RF)
Front Hub Assemblies (L&R)
For a 2002 F-350 4x4 CCSB 7.3L:
LF Wheel Speed Sensor
EBPS
EBPS Tube
Also, calipers (cores) should be shipped back today!
