sunrisefordparts
8 injectors for a 2003 6.0. Also the the stand pipes and oil rail hoses
inj list $264.29 each sell $212.75 each w/ exchange (core $180 each)
stand pipes list $66.25 each sell $47.70 each
lh hose list $95.55 sell $68.80
rh hose list $86.72 sell $62.44
shipping $20 to cover all 8 inj there and back
q#321329
JD3020
Farmersville/Dayton, Oh
I need a quote for all the the cab mount bushings and hardware for a 96 F-250 supercab. I think its a total of 12 rubber bushings, and then 6 bolts/nuts/washers etc..
sunrisefordparts
heres the quote for whats still available from ford, and the picture of the mounts. the front cab mount bolts, and lower nut are obsolete and the lower nut is also used on the rear cab mounts. the bolt is a 7/16-14x3.80 you could prob get a nut and bolt and a large flat washer on the bottom to work without a problem.
  • Q321452.pdf
ford_trck
Vail, AZ
Turbo for an 05, and also drivers side engine mount.
Can the vanes, turbine wheel and shaft be had without buying the hole turbo?
ncollins64
winchester springs, tn
Front and rear paintable bumpers for 08 superduty with the black plastic molding for both. The rear has the back up sensors. And driver and passenger front inner fenders for same truck. Thank you
RSK
Connecticut
aren't your bumpers already painted? or is this for someone else.
sunrisefordparts
they offer the center section seperate from the turbo and the unison ring. nut could i get the last 8 of your vin to price you correctly.
