sunrisefordparts
Rear Hub Seals - #2C3Z-1177-AB (Qty 2)
- Axle Shaft O-Rings - #E5TZ-4A331-A (Qty 2: Thanks to Guzzle for this one)
- Oil Slinger (I Broke Mine) - #F81Z-4670-AA (Qty 1: One per side; May Vary with model year)
- Inner Bearing - # F81Z1244AB (Qty 2: Cone Only Does NOT Include Cup, and please double check this Ford Part Number); Also TIMKEN# NP114036 09719 USA YZ081Z
- Outer Bearing - # C7TZ-1240-A (Qty 2: Cone Only Does NOT Include Cup); Also TIMKEN# LM104949 778 08 YT
- Inner Bearing Race - #NP064306 (Qty 2) Sourced from NAPA
- Outer Bearing Race - #LM104911 (Qty 2) Sourced from NAPA
10 ford wheel studs also
this was a copy and paste, but do these part numbers match up to a 96 f350 rear end also?
does you truck have a full float rear axle or semi float? these numbers look like the newer sd axle with disc brakes.
sunrisefordparts
Can I install switch bezels in the xl panels I have now if so I'll go that route if not gonna buy a set of lariat panels from the junk yard with switches already in them
Sent from my SM-G900P using Tapatalk
if you went that route with your panels you would have to run an aftermarket rocker switch for windows and door locks otherwise if you got the panels cheep enought that would be the cleanest and easiest way to have your switches.
sunrisefordparts
For shats and giggles...
For a 2004 F-150 4x4 CC Lariat w/ 5.4L/auto:
Wheel Speed Sensors (LF+RF)
Front Hub Assemblies (L&R)
For a 2002 F-350 4x4 CCSB 7.3L:
LF Wheel Speed Sensor
EBPS
EBPS Tube
Also, calipers (cores) should be shipped back today!
heres your quote, same order as you listed.
  • Q320974.pdf
Taylor D
Sebring, Florida
Okay figure it as if I have the switches and door panels already
PSDSeven.3
Can i get a quote for my pile of parts please? Thanks
Front leaf front bolt (2)...........w704660-5426
front leaf front nut (2).............n807659-s427
front leaf rear shackle bolt (2)..w500593-s439 these should be leaf to shackle
front leaf rear shackle nut (2)...n800237-s301
x code front springs (2)............2c3z-5310-af
front super duty u bolts (4).......f81z-5705-za
socket (2)...............................f81z-13411-ba
pigtail (2)................................1u2z-14s411-bea
shifter knob for a 6 spd manual
08+ tail lights (2)
cab lights and harness for a 2000 SD
bottom of door weather stripping for a 2000 crew cab all four doors
gr8white
May I have a quote for the lower plastic front bumper valance for a 2008 f250XL, and everything needed to install the factory fog lights. I'd assume it's the lights/brackets and interior switch. Thank you.
sunrisefordparts
on the valance i quote both the 2wd (short one) and the 4wd (tall one), and the headlamp switch i priced the swtch with foglamp and non auto lamps.
  • q321099.pdf
sunrisefordparts
08+ tail lights (2)
heres the quote, in the same order you listed, i updated all the part numbers to the correct ones and the harness for the cab lights is obsolete from ford and i dont show any dealers stocking the harness.
  • Q321106.pdf
gr8white
Thanks a ton for the quote. I really appreciate the time taken to look them up for me.
I don't know if it's possible, but is there a way to put together a parts package to convert my manual on/off lights to the auto version w/updated fog-headlight switch. Thanks again.
sunrisefordparts
i believe thats a little more complicated, it would involve the sensor, wiring, and i think the computer has to be programmed for the auto lamps.
