205cc\100 + s366 = ? and my build
slim613
are yall sayin a 100% will burn a hole in a piston before a 200% will with correct tuning?
bruce
Middle east
burnin a hole in a piston isn't really a worry of mine, the long pw like stated before is. the 100% nozzle is eh and the 80 and 200 are both edm, 80% is crisper imo, it has better atomization, tuners are comin around with the 200% idle though, the more common they become the better the tunin will become
slim613
so a S366 and 180/100 are a good combo?
97stoker350
south central pa
Bruce has a point tho it's whether you believe in getting bigger and detuning or getting what you need and using all of what you have. That's basically the difference between 100% or 200%
Milford
Plainfield, IL
Tycorr, you're saying people have chunked forged rods with 238/100's or burnt holes in pistons with them?
Yeah, I have seen a few motors go with stock injectors and one with no tunes even! My PMR lived with stage IIs from Cass with the right tunes and that was 6 years ago! With the right tuning especially if you pay for live tunes you should be fine! 175/80s and a modded H2e would be a KILLER setup for towing and DD. You could pull anything behind you and still unhook that trailer and roast the tires off the rim!
I am doing a forged rod motor for my truck also. I am going to go with a 250/200 and I am still undecided on the turbo. I am not going to have my tunes setup for balls to the walls, probably have it held back to the 500 mark roughly! I will say it again as will others, its all with the tunes and how you treat and drive the beast!
slim613
mine will be live tuned as soon as i got some miles on the fresh rebuild but im not gonna make gear head give it all shes got if i went with the 250/200 but i cant so idk what im gonna do iv never had it down the strip but its also been stock that might change with some HP who know i prob wont hook up too a sled but maby once just too see what she does mainly dd/ tow and sometimes i get called into work and gotta be in a hell of a hurry
iv got a block at the machine shop as we speak
codes?
Yea, people have decimated **** with 238/100s. Jake(lincolnlocker) burned holes in his pistons with 170/100s. If you wanna make 500hp why not run a 200% nozzle? Why hold an injector open longer than hell and burn it up. Slam the fuel in quickly, make the power and get the ***c out quick.
To the op, Bruce said "A codes". Its the type of injector that the stage 1&2 are made from.
Well, pick your poison. You gonna daily drive it? Race it? Race it and you'll probably blow the block in half or window it. Dd? Probably burn a hole in one of the slugs. Both? Probably race on Sunday and two.weeks later cruising a 35 mph zone and a rod will let go, "out of nowhere".
slim613
are u speakin to me or someone else?
If you read the post above that, and the one above that you'll see that they are dialogue. I didnt quote ghohouston because there arent that many posters and i knew he'd figure out who I was talking to.
slim613
quick stupid question need asap 100% conformation a E99 cam is the same as the rest of the 7.3 cams correct? .. thanks
