24x12 / 4" or 7 lift" / safety?
Bswain
With 37x13.50s and 24x12 with -44 offset and 4.75 backspacing on a 6 inch will I be ok what will I have to cut?
BostonPowerStroke
I'm dealing with that right now- I got 24x12-44 with 37x1350x24, and everyone told me I would need an 8"... I bought a 7" icon and hoping that I don't have to do much.... It's the low offset that makes it a problem for these trucks
BostonPowerStroke
I should be putting it in in the next 2 weeks or so, they are still putting the kit together at icon
BostonPowerStroke
sno-x139
Does no one remember coltons platinum? 24x12s/37s on 4.5" lift IIRC? Yeah he had to do some cutting but it's ****ing sick.
BigByrd_6.7
Florida
American force 12 inch wide wheels have a little less - offset then most other wheel brands afs are -40 most others are -44. The with of your tire will also make a difference on how much they stick out. Those 12.50 appear to be a little bit stretched and don't stick ou as much the opposite goes for the 13.50. Hope that helps a bit. I run the set up mentioned 22x12 American forces and 325/50r22 toyo at 2s except with a 2.5 inch lift you don't have to trim much and I would recommend it to any one. Good family hight to. As they said 24x12 37s and a 4 inch Lift won't work unless you want to cut some major stuff. My uncle runs 24x12 afs and 37s on an 8 inch lift and still scrubs on the front valence. Unless you do any thing stupid in it your probably safer that high his truck rides good.
Hope this helps.
Houston
Hope this helps.
What spring/block combo is he running in the rear. I need to ditch the Procomp a-a-leafs. Already replaced front coils.
I'm running 8" lift with 37x13.50's on 20x12's with -44 offset. Rubs the valence only in certain situations.
