6.7 Fuel Rail Pressure Drop with Hot Tunes
BK39
Texas
Yes sir. Stock lift pump has 210k on it. I was telling a guy how well it was doing as he is getting ready for number 3 on his 2014, so I probably jinxed myself.
This is good to know. Mine did it the other day getting on the freeway, 0-80mph. Blah, just died. And I only have 11k on my truck. Guess it has a weak pump. :eek:
Buck1
Winchester, IN
No extra noise on mine. I did just change the filters. But I was thinking the same thing. Never happened before, but maybe I was taxing it more than usual. So the question is low pressure or upgrade high pressure?
dseitler
Royal Palm Beach, FL
When I started this thread it was in reference to a drop in rail pressure not supply pump pressure. The code you are referring to is a drop in rail pressure where your CP4 cannot supply enough fuel to maintain the rail commanded. Pulling up hill is a perfect example where you can run your CP4 out and not supply your fuel rail with enough fuel to maintain pressure and it will shut off. LPFP will send a different code if it does not supply enough pressure.
Buck1
Winchester, IN
10-4. Thank ya sir!
dseitler,
We're glad that the pumps cured your issue you were having. As Zane said, this kit works excellent on stock or modified trucks.
I wouldn't run a dual fueler without a lift pump. The stock lift pump struggles with tuning alone on some trucks. I would suggest doing a lpfp at the same time.
UNBROKEN
I have a new LPFP going on this weekend when I delete everything. You know...just in case I need it later. lol
