6.7 Twin Turbo Setup
Fast-6.0
Alamosa, CO
Highest power I made was 1018 on fuel.
After tweaking was able to consistently get 1002-1004hp with less fuel and less timing. Peak power was at 3950 rpm.
4EverBoosted1
woah that's very high in the RPM range. Great numbers though!
97stoker350
south central pa
That seems low compared to what kaleb made with a lot less air. Maybe it's the elevation and tires robbing the power. Great numbers none the less
Fast-6.0
Alamosa, CO
Honestly comparing dyno numbers like that is a waste. Two trucks, same dyno, same day, then you can compare.
bluedevilslax
Castle Rock, CO
I hope you guys are going to be able to lower the power band to get more power out of it here at elevation with out having to get into those high RPMs to make power.
taterthedog
Canada
Any nitrous on this truck for the event? Also we're these dyno runs at a similar elevation to DPC?
bigrpowr
<How I Fly
Administrator
They're Dyno tuning it in Arvada.
bluedevilslax
Castle Rock, CO
Mikey I know they are out here doing tuning. I was just hoping that Tadd could get the band dropped before Tuesday so this truck won't do be so laggy.
