ghohouston
So after dealing with my stock mechanical fuel pump crapping out, and knowing they're not a great design anyways, I have an idea. I am not going for big power on this, but just want a cheap, cleaner setup than the stock obs, and I will eventually upgrade injectors.
Get a super duty fuel bowl and electric pump
Swap hpop resovoir to sd style to mount stock sd fuel bowl (I have one laying around, so its free minus cost of gaskets)
Figure out what I need to do for fuel lines?
Could I make fuel feed lines to go to all 4 corners of the heads, and have the excess fuel returned still through the stock return? The stock sd setup has the fuel returned at one end of each head, then back to the bowl, and back to the tank from there, correct? What could I do here? Would I be forced to run a regulated return? Any ideas from yall would be much appreciated. And if you're just going to tell me, buy a fuel system, don't bother commenting. I am detirmined to make this work, and am looking for ideas. Thanks in advance
