Anyone interested in a DYI Billet 66mm OBS-E99 Kit
NRHX2009
Elizabethville, PA
Yeah, there is one in Pine Grove. Stumps Garage. Its like 75 bucks for 3 runs. I'll cover the costs. Only little problem is no results with a stock turbo vs 66mm.
The only bad thing is the dyno is normally booked on the weekend.
OldschoolPSD
Central VA
I think we could swap the cover and wheel on the truck if you have a spare stock set. That way we could get back to back runs.
NRHX2009
Elizabethville, PA
It might... I have a stock wheel and housing but the turbo needs pulled to do the swap :/ time consuming on an obs.
I'll get results with my e99 eventually. But just to do a run would be great with your truck.
I'll let you know what day next week he can get you in. Any day? for me it has to be 3:45-4:00 dyno time.
c69ss396
I might be interested in giving this a try in my truck, It could give you some real work truck results.
OldschoolPSD
Central VA
38.2 psi before it defuels. I'm gonna build a boost fooler tommorow.
I've been chasing a short in the engine harness but I got it figured out now. Should have some real numbers for you guys soon.
OldschoolPSD
Central VA
The install is **** simple. If you don't want to do it I'm sure you could get just about any local shop to do the install. Pulling the turbo is the hard part, modding it is gravy.
IMHO its definately not worth pulling the turbo and sending it away. If you can pull the turbo yourself then you can definately install the new gear into the turbo.
NRHX2009
Elizabethville, PA
Here is a Dyno Sheet. Specs:
E99 6pd 233K, 175/80's, t500, full fuel system, My 66mm turbo with 1.00 A/R non wastegated turbine housing
Billet wheel made the same Peak power as the cast, but made more power sooner in the rpm range. More power over the cast version of the 66mm wheel up until 2600rpm.
View attachment dyno66mm.pdf
fordman2121
huntington, in
What did this truck put down on stock charger? 325 ish guessing. If so that's a nice increase even if it was 350 that's still 25 horse.
NRHX2009
Elizabethville, PA
Didnt dyno stock charger yet, hopefully this week i can get some more dyno time.
QUOTE=fordman2121;662408]What did this truck put down on stock charger? 325 ish guessing. If so that's a nice increase even if it was 350 that's still 25 horse.[/QUOTE]
S
