If you have combustion gas getting into the fuel rail in a head, it will stall the engine. Have you bubble tested? One injector could be doing this but it will cause terrible missing on every hole in a bank.
Number one was not torqued tight enough in one of mine once, it took a thousand miles to start showing up. Was much worse cold than hot. Also, the bubble test did not show my problem, AE showed the missing on every hole in the bank, which led me to pulling injs on that side and found copper washer on #1 was completely gone. Inj hold down was very loose also.
