Ball joints and wheel hub discussion
91turbogsx
Gardner MA
I've been getting Ford greaseable ball joints for less than Moogs and are comparable to XRF pricing. Just make sure you ask for the greaseable ones cause the actual OEM ones are not greaseable, more expensive, and don't come with any hardware. The greaseable Ford Motorcraft ones come with all hardware.
I had stockers for 100k. Changed em all to Moog and those were pretty much junk. Not the brand we all knew. I got some from the local tire shop I think they were made by walker. Called wildcats or bobcats(balljoints) those were awesome. Lasted another 100k. Did them two falls ago with cheap junk.from oreillys when I did my brakes and they are still working but ive only put 18k on it since then.
Im going to xrf for everything next round!
YoungMT Hick
Lake Stevens, WA
Ok with all this talk about which ones are good or not I would like to know what is the symptoms you have been having to make it be the wheel bearings or ball joints that are going out? I am trying to figure out where i need to be looking for a shudder i am having on the highway.
Depends on if you feel it in your ass or in the steering wheel?
YoungMT Hick
Lake Stevens, WA
i guess more in the seat. it is pretty even on both sides. just a constant shudder on the highway, no specific speed, and no sound. just seems like the front end is bouncing/shuddering.
Another thing on the wheel bearings, if you have your window down it'll squeak as tye steering wheel is turned from side to side in drive or.reverse. Moving a little bit obviously. Also, when a wheel.bearing starts making those sounds, there is no amount of time. Ive had them disintegrate two days after the first hint of trouble.
I ran some "wildcat" bearings that oreillys used to have and they made balljounts too. Those were discontinued in 11 or 12 and now ive got xrf in my 00. Good so far.
rascal
TX
x2 on the Dynatracs ball joints and fixed spindle.
Went with the WARN hubs though. Did not spring for the Dynalocs.
TrailerHauler
Michigan
I think I'll be going with Spicers/ Reybestos for my next ball joint replacement. Haven't heard anything bad about them yet.
FrankTheTank
Cecil County, MD
Has anyone seen Carli's new ball joints? They only have them for dodge right now but they are guarnteed for life like the dynatracs..... BUT..... If u have one go bad they do not send u a rebuild kit, they send u a new one free of charge! $200 a joint tho...
07_powerstroke
Upstate, NY
I have 15,000 miles on my xrf joints 5,000 stock tires 5000 14 wide wheels and 5000 with 12 wide wheels everything is good so far.
