Black Magnum 2.0 assembly
Magnum PD
VA
Just about got the other harness ready. Soldered on two new injector plugs and will have to change the oil temp sensor for the other harness.
Magnum PD
VA
Well good news is that got harness changed over and installed and the truck fired up.
Bad news, still goes into the god damn default mode :cursing::cursing:
If I need ANOTHER IPR or send in the rest of the injectors to be checked out IDK
Magnum PD
VA
If I gotta do it, I'll do it. Just being stubborn about it. Not hard to do.
Jomax
Arizona
I think I still have a good spare IPR. If you cover shipping, I'll let you borrow it. you could see if an IPR fixes it without having to buy one.
Let me know.
Magnum PD
VA
I got me spare IPR coming back to try.
One thing I was thinking about is the actual HPO psi is a little higher than what my electric HPO psi says. Don't know if that matters or not.
I'm not that impressed with the G head tunes. My all out setting still has the rev limiter. Dyno proven tunes would turn my truck into a "monster", G head is just ehhhh. "That's it?"
Strokersace
Towanda, KS
I wouldn't be comparing tunes until you figure your issues out...
Once it's running without issue, then you can adjust tuning.
Magnum PD
VA
Could there pressure loss at the Gen3?
Need to find the plug for back of the hpop.
Magnum PD
VA
Did a couple things to truck, one thing I néed help on, at the ICP sensor, one wire has 5v another wire gives feed back to PCM. The last wire, according to my brother in laws truck is grounded, but isn't. Should I try to ground that wire to see if that changes anything?
i think that the voltage is correct.. not sure on the ground... did you take the Gen 3 off yet?
Magnum PD
VA
That's where I'm guilty being stubborn. Back before I rebuilt the engine, I did take the Gen 3 off. It made a difference, but why?
Magnum PD
VA
I put a new Haldex pump on. I think the problem is electrical. If the ground at the ICP isn't the issue, I'll take my Gen 3 pump off
79jasper
skiatook, Oklahoma
It is supposed to be a ground.
But I don't know if it grounds through the pcm/idm, or "frame."
