coolant leaking from head stud nut
You could even run a 200/200 and that adrenaline will be plenty. They use less oil than stock injectors.
If you go to bigger injectors (hybrids) you'll be set on oil anyway. Unless you go past a 200% nozzle. My truck ran fine and good with 250/200s and a 15deg pump when my srp exploded. Didnt even piss with tuning.
im thinking more of a custom t4 2.5 turbo and 300/200s or 400/400s or whatever the new thing is by then... or a really huge external gate for the 38r. lol
A 300/400 is a "thing" too. Everybody else is buying the largest injectors they can find and choking them down with 200% nozzles.
200% is a 550hp nozzle.
I honestly wouldnt run a 200% on anything bigger than 250cc. Just my take. It seems like a 200cc a code with a stock nozzle at that point. Relatively speaking. Like whats the point? A 200cc hybrid with a 200 nozzle still makes over 500 all day. That 250 buys you another 25hp. The nozzle is working at that point. Not trying to start anything here but after a 250cc it seems time to up the nozzle.
hows that truck working after being at morgans?
sitting in the shed collecting bird chit... voltage dropped to a hair above 12v the other day when my brother took it for a spin.. been battling that issue since last summer.. morgan never got it to drop enough to cause concern.. she just hates me for replacing her with the 6.7..
Jomax
Arizona
Start swapping parts with your red truck to see what fixes it.
Bustedknuckles
nope.. its drawing it down to 12v.. i have tried 5 alternators off running 7.3s.. all start at 14v+ then slowly draws it down..
Try unhooking the glow plug wire n then the starter wire, see if you cant narrow down what is drawing because it must be a pretty severe draw! Have you tried new batteries?
its on the todo list.. but gpr works fine... batteries are diehard platinum p2's 4yrs old.. but now that you say that i never have load tested them.
Those are the only two things that would draw that kind of juice....starter is ***ked and is drawing.
pdumont01
CT
I think I have a starter or battery problem as well, I load tested my batteries with a toaster they held OK, I'm thinking the starter is drawing on mine.
pdumont01
CT
Lol the older load testers glow like a toaster when you are using them, we always called them toasters
