Lassie
{And I've noticed I can set duty cycle to a certain percentage. What is the point of that?}
You can prove to yourself that the IPR is making a difference to ICP. When you command this, watch ICP, it should change according to the change in IPR.
If idling at 30% IPR and 580 PSI ICP, change to 40%, you should see increase in ICP and you will notice change in idle smoothness. You can also drop IPR and shut the truck off.
