6
6.4stroke
Guest
This is very interesting even tho I have a sct the controllability in this software is overwhelming. I might screw with this software
No you will have to change all the back pressure tables to make that happen.
What do you consider high back pressure?
The back pressure deviation tables will only change whether or not it throws a code if the back pressure doesn't match desired.
Another thing you need to check is see if the vanes are going to 7% at wot. If they are try changing the tables to 2% and see of.that helps.
Before pulling rail.pressure or pulse width back I would pull timing back first that should take some back pressure out as well as lower cylinder pressure
Well one thing i havent totally varified is that back pressure is in absolute or in actual psi, from what my truck does it looks like its psi and not absolute. 68psi of back pressure really isnt that high, considering boost is prob around the 50 psi range, your just about 1:1
IF you retard the timing you cant hurt much, getting into advancing the timing is where you can run into issues
Yeah sorry
Your looking for injection pw in us which is read as 2168 or 2.168 Ms
So look for numbers like.that you are going to see numbers based on rail pressure so.at say 24600 the number will look like 2186 on hot 1898 on wild 1535 on mild and 1300 on stock.
Basically only look at the own number at 24600 psi the rest of the graph will only be part throttle then look at your mm3 and look st that about 100 -110 mm3
It's hard to look at because there are lot of.parts on that graph that the truck never hits so some.of the pw numbers are huge and others are way small but just remember you won't hit 26000 rail at 30 mm3
