Based on this brief description - I would say you have an issue somewhere - and its in the HPO system somewhere... that means oil feed to the reservoir, reservoir, pump, IPR, lines, injectors, etc... Your truck should be snappy and consistent. Start a thread here that outlines your issues - I've seen the huge thread over on PSN - and honestly I haven't read but a fraction of it. Of course I'm going to ask for some AE info that you don't have, I'm going to ask what oil you're running, as well as any additives, and I'm going to ask if there are any scenarios where it always seems to run great, or it always seems to run like crap.
Reliable is jumping in, turning the key, and not worrying about it. Period.
We can get into the merits of compounds - but until you fix the underlying issue - it doesn't matter, throwing more money and turbos at it won't fix it. You have a solid base that just needs to have the "kinks" worked out - and unfortunately I have yet to see a build that didn't have some kinks. These aren't like small block chevy engines where you can almost go down to the grocery store to buy parts and they work out of the box.
To give you a for instance - last summer I did what I call a "medium power build" for a local guy that is doing nothing but truck pulling his truck. It has a Gen3 pump, Custom S400 charger, 400/200 sticks, fuel system, etc... all on the stock bottom end (forged rod truck). I didn't get a chance to fully test it before it left my shop due to some parts issues and timing and whatever - the list goes on... the truck ran good out of the gate, but then performance started to suffer, and then suffer some more.... I brought back into the shop and started diagnosing.... I found it wasn't making ICP and started to track down issues.... first thing I found was a blown seal on the front of the Gen3.... fixed that and went testing again.... it was noticably better, but fell off after the initial punch.... pulled the sticks because of some development work I was questioning - nothing wrong... pulled the stock HPOP and the IPR - tossed it all back together and BAM - runs like a champ, launches hard and pulls like a damn freight train. The moral of the story is its probably not one big issue plaguing you - its lots of small issues making your experience less than desirable.
