Tom S
- Joined
- May 20, 2011
- Messages
- 3,365
- Reaction score
- 1
I bet your truck has had a chip or tuner on it before with an intake installed.
You won't regret the tuner. . .
Just buy the F5, put the 100HP tune on it, get gauges, and lose the K&N. BHAF is cheap and easy stock air flow upgrade. (search. . .it's all there)
You're not going to see mileage gains for a long, long, time. . .maybe ever. This is mostly because of the giant retard grin you'll get every time you hit the throttle, which will make you hit it more. . .
I drive around 99% of the time in the 80e tune. I love it.
I use the 60 when I tow heavy just because I love the shifting.
You gotta pay to play though. . .I have less into my truck than a lot of guys but it still was far from cheap.
Beauty stock truck though. ..that thing is clean.
I just want to throw in that I've had my DP F5 for 5 years now and it has pretty much never left the 120 tune. Stock trans is still going strong. As reliable as I could ever ask for.
I drive stock 7.3's from time to time and I can't understand why someone wouldn't have a tuner of some sort. They are so much easier to drive tuned IMO.
We have an assortment of mounting pods available for your EGT, Trans, and Boost gauges. Besides the standard A-pillar pod, we have a windshield pod that mounts them above the rear view mirror, the single pod for the steering column, and a three gauge cubby pod that mounts them below the dash.
Let us know if we can help, can put together a package with the tuner and gauges.
Oh I know.. Im just saying, why do they offer 16 Pos.... I mean how many actually use even half of those.
The only benefit I could see would be tuning tweaks over the phone. Jody could send a number of files to try to get 1-2 tunes completely dialed.
And I dont have to count, Cale gave me a purdy lil sticker the 1-6![]()
BTW: I just cleaned this thread, no tuner wars on this one.
Could just be a hardware thing, they may have wanted more than 6 just for that reason. The guy that actually buiolds the chips may have said the next option from six would be sixteen.
Gauges would be the performax if I had to do again or the money for it. I have had great luck with the autometers. Pyro was in truck in 2007 I added boost and trans in 08 along with chip. No problem so far... oil at least the Ford motorcraft is semi synthetic I prefer AMSOIL as I get wholesale and my truck idles smoother and runs better. ( I have had to do a Mobil change as I was tight on money after 15k of AMSOIL then back to Mobil I have been fixing leaks like crazy.) 15 k before was leak free. Then I switched oil and lost fuel pump, then o rings on Turbo then valve covers which better be last. Because I'm losing trans again but 50k miles on a aamco rebuild seems bout right.
Long story short fix the easy things before added power shows the problems you have
Sent from my PC36100 using Tapatalk 2
After 6 years on the market I am still shocked at the fact people don't understand how we ended up with 16 available positions. Like I've explained from the beginning...
Just to refresh some memories, we asked for 8 and it was determined by our manufacture the memory chips were not a huge difference for more memory. We don't make anyone get all 16 positions, but its there if its needed or wanted. Another reminder that during live tuning tunes are all inclusive with the cost of live tuning and that is when most everyone gets all available tunes they can load on their chip.
Diane
15k with the same motor oil? The same motor oil that is used to lubricate your engine is also compressed at over 3000 psi to fire your injectors. . After time and I mean long before 15k it starts to "break down" so says many tuners I've spoken with
I know synthetic is designed to combat issues like this but I would never go 15k on a HEUI system with any oil
I wouldnt worry about synthetic.. Change your oil every 3k with moto craft and you'll be fine. My truck is producing upwards of 500 rwhp and I've never had an issue
I ran 15k I never said all at once. 5, 10, 15. After running that for a year and a half I switched back to delvac. That is just old thinking on the 3 k changes and if you want to do that fine do it.
Maybe there us a reason more and more OEM cars and trucks are coming out with recommended 10k change intervals as oil is being manufactured better and not breaking down.
Don't insult me with your knowledge because you have a 500 HP truck I could care less. I have done my research and tested as needed. Thanks
