Edge CTS questions
BFT
southern cali
ok, how the eff do i get this dashdaq to turn off with the key, or did we cover that. i keep leaving mine on since my CTS turned off.
you just turn it off the truck, depending if you have it timed to turn off if its not in use, but it wont turn on with the truck.
powerstrokin15
Charleston, WV
ford day and night themes.
Dzchey21
wyoming
thoughs look good, how did you format the sd card to make that work? Im trying to help monstar figure his out
powerstrokin15
Charleston, WV
josh(jhaddox) came and stuck his SD card in mine, downloaded his skins and then removed it.. I didn't even take my DD out if the truck nor do I have a SD
