Head gaskets blown...again.
mcdaniel1991
Germany
Yepp, it was leaking between layers. Matt sentence this picture this morning.
DEEZUZ
NO PUKESTERS
NWI
Refresh my memory. Did we discuss block prep in this thread?
I am also not familiar with extreme studs. What lube do they use and on both the top and bottom of threads?
mcdaniel1991
Germany
Yes extreme studs use lube on top and bottom. I used the recommended engine assembly lube.
Block prep was done with a flat board and 320 grit sandpaper.
mcdaniel1991
Germany
Maybe it was just talking about the top threads but I think I put it on top and bottom.
Thats why i'm wondering if the studs backed out. THe purpose of lube is to allow you to get to a given torque without galling the threads. When you are putting the studs in the block, you are just seating them-not achieving a max torque.
DEEZUZ
NO PUKESTERS
NWI
He said he re torqued... OP did you get any more turns during that?
DEEZUZ
NO PUKESTERS
NWI
So that narrows out 2 things. Studs backing out and stretching. All that's left is block prep and head surface. How are they checking your block surface?
junglejoe
Mo
Seems he got it back pretty quickly! Good to know! Everything good? Anything to tell what caused all this?
mcdaniel1991
Germany
Well Matt said it's hard to prove but he thinks the heads weren't flat.
This was after surface sanding, you can see the low spots.
junglejoe
Mo
How's the truck running? I popped my head gasket now, so I'm in the market for a reputable RELIABLE shop to do my studs and gaskets..
