MadDiesel73
jesus 2200..
Someone needs to come up with a stainless valley pan and drip catch can combo for our motors. The low spots for oil to collect in are just stooopid.
:whs:
David - I'm sure Jon can fill you in on what was discussed between him and I.
I was interested in picking up a set of these. What was the out come? Did you get taken care of on your issue?
So does this mean that my very old set of headers that have held up to god knows how much abuse is well worth the cost of a new set today? Mine have seen EGTs that would make most of you cringe (my gauges went to 2200* and it would reach that within 15 feet of leaving the line with the sled....). Mine have never warped and mine have never cracked. I wonder if its a difference in setup that made mine work..... I used a T4 mount that used solid up-pipes instead of having bellows - my back pressure was almost always in check with a maximum of 60psi with 50psi of boost (where I wanted it). But then again these are OLD.... I would have to look them up, but I probably bought them in very early 2007.
