Honey badger Jr installed...
CSIPSD
Bend, OR
Joe how long did this take you to do and what other little things did you have to buy? Like gaskets and such. My stock HPOP is shot so I'm looking into what gaskets and Orings I need to buy desperately from the pump. And a time frame as well. Thanks.
Came with the HPOP to Res gasket and thats all that is required.
Old pump and new pump... The gasket is not shown but it comes with it...
Not sure if they all come with the HPO bolt cover or not, but mine came with one...
I would order up Clays nifty HPO line tool, I have one and LOVE it!
http://www.riffraffdiesel.com/hpop-quick-disconnect-hose-removal-tool-99-03/
Keep in mind I dont have a fuel bowl which makes this much easier, but from start to finish I doubt I had an hour in it... You may order a toolbox kit from Clay in case you have any leaks from the fuel bowl removal...
http://www.riffraffdiesel.com/mechanics-parts-cabinet-combo-kit/
or
http://www.riffraffdiesel.com/complete-fuel-bowl-seal-kit-99-03/
Dmstrucks02
Pearland, TX
I bought a used adrenaline hpop, so I had to buy a new gasket for pump to res. I also put on new IPR O rings.
I had never changed a pump before and had a few mishaps and it took me about 5-6 hrs with the stock fuel bowl left in place
Sent from my SAMSUNG-SGH-I537 using Tapatalk
dsberman94
Pennsylvania
Thanks joe. I'll probably order both of those items from clay. Anything to make life easier in the end. Hopefully I'll have this done by the beginning of next month so I can throw it on Ryan stumps dyno and see what she makes.
