Lifted 6.7's
mattmal9
Severn, Maryland
I have a 2011 350 SRW 4x4. If put a 3" level kit on the front would i be able to clear 20x12 with -44 offset running a 33" tire? I love the stance that creates but i also don't want to deal with a rubbing issue. Ive heard yes it will fit an Ive also heard no, just looking for some clarification.
Also out of curiosity, if i level the front 3", what do you guys recommend for lifting the rear? I'm not one for the "Cali" stance, but would like the truck to almost have the factory slope or sit level.
Thanks in Advance!
Powerstroke214
Baton Rouge, LA
Thanks in Advance!
4.5" or 5" block
4" block gives a stockish rake to a 2.5" level.
Platinumtoys
Greeley Colorado
Here is my2013 platinum. Sitting on 3" RCX stage 2. With 2" rear block. RCX dual steering stabilizer 295/55/20 nitto trail grapplers. 20x10 AE series 016. Ranch hand front replacement.
3-3-14 all coming off after 4000 miles. Going 6" fabtech with 37 nitto mud grapplers. On 20x12s. Soon to follow that is amp research and delete kit with H&S mini maxx.
Jayz
Thanks in Advance!
Yes! My buddy has 4" lift same wheel specs n clears 35s no problem
Jayz
You should be fine depending on the kit.
Depending on the kit?! Negative, depending on the off set of the wheels! It won't clear though, most 12" wide wheels are -44 offset, way to much for a 6" on 37s. 6" with 37s is gonna be a 9", 10" wide wheel max no more then -18 off set to clear....I think even a 10" wide wheel with -24 is to much off set.
SWIFT
Based on my 4.5in lift and 35's on 22x12's with -44 offset. A 6in lift with 37's would clear without issue even with the 12in wide wheels. Thats why I said depending on the kit. Some kits are higher than others once its all said and done.
Mine comes nowhere near rubbing
Platinumtoys
Greeley Colorado
I know plenty of people with 6" lift. 12" wide wheels and 37s.
As for the 3" with 20x12s and 33s. I'd say it'll fit mine right now has 20x10s (-24 offset) Basically a 35 and had no rubbing issues everyone said I would. Even installed ranch hand front bumper.
Super08Duty
College Station, TX
False. 6" is more than enough for 12 wides and 37s. Even with -44 offset
Super08Duty
College Station, TX
False, you wont clear 37s on 12 wides on a 6 inch kit. I rubbed with 10 wides. Why do you think I went to a 8 inch lift?
I'm clearing 12" -44 wheels with my 37's on 4.5" of lift. Trimmed the bumper a little bit and trimmed the fender liner a couple inches up. Passenger side barely rubs the finder liner at full lock in reverse. It's not optimal, but it's not impossible either.
4EverBoosted1
BOOM!
mattmal9
Severn, Maryland
Do you think if I run 33's on a -44 I would rub at all with a 3 inch level?
SAK
Victoria, Texas
Your definition of clearing and mine are two totally different things.:pimp:
PTSUPERD
Granted...fenders are different on yall's trucks but I needed 9" to feel comfortable with my 37s on 12's...
