Since I'm wantig to swap over to the column shifter can I still keep the manual gauge cluster (since the PRND won't work)? Is the key cylinder easy to swap between the manual and auto steering columns?
On my 99 you insert the key into the cylinder turn the key either to ACC or Run and there is a small little check ball in the casting around the cylinder that you depress and pull the cylinder out with the key in it. It clicks right into an empty column.
On my 99 you can use either the auto or manual gauge cluster. In fact, they are exactly the same, the manual just has a block-off module plugged into where the auto range indicator would be. I actually removed that from my manual cluster and snapped the automatic range indicator in it's place and retained my original cluster.
On the 6.4 the range indicator is LCD??? In which case, does the manual cluster have the screen there? If not, is it modular and simply clicks in place?
I wouldn't be surprised if it swapped over easily. Everything I have done on a superduty in terms of swapping things around has been plug and play. Ford generally keeps their options open and cuts down on specific production lines by building things mostly the same, and then optioning specific things toward the end of the line.
