MPD Single turbo kit
bigrpowr
<How I Fly
Administrator
looks and sounds awesome. im sure the tight housing helps a ton... might want a gate now though.
lubeowner
Platteville, wi
Sounds awesome and looks to have great power. So this is with a stage 2 fuel system, Dragonfire pump and 100% over injectors? Looks like you could use another pump with only getting to 140 mpa. I bet the truck would be even more crazy with 26,000 psi instead of 20,000.
Erikclaw
Central CA
Is 100% over equal to Elites 110hp injectors? If so the stage two fuel system should hold 26,000 no problem. If that is what he has on the truck.
Mike@MPD
Pasadena,MD
About the Back pressure, at idle its 120mpa so at full boost its at around 540-580 so you need to take away the 120 so in reality its only about 420-460mpa, im pretty sure they are equal to 110's, craig has the airdog with the elite add on
Jeff@Spartan
Georgia
If those are 100% over injectors, they are beastly. I would guess either custom tuning is required or the Industrial pump ain't keeping up.
derrick36
Heres craigs new setup Bullseye s475 batmowheel, 100% nozzles and II pump, the funny thing is this setup spools great with the .90 housing on it, vids to come
Are we talking spool up as good as the S366, spool up better than the S366, or spool up better than the S372 you have but not quite as good as the S366?
I might have missed it. Did Jeff's question ever get answered?
That single sounds awesome!!!
eric.davis
Norfolk, Va
He means kpa or else that pump is making over 60,000psi lol. If holes are in the pistons we know why
Mike@MPD
Pasadena,MD
Spools just about as good. My turbo doesn't because of the massive 1.0 open housing that is getting changed shortly
Sent from my Droid Charge using TAPTALK
CAT35niner
NJ
I dont wanna start anything about the percentages to elites injector sizes but from wat i heard 100% is bigger then 110s.
Craig@MFI
If I recall 110s are 60% and I have 100% nozzles still need to dial it in and get a boost guage on it
Jeff@Spartan
Georgia
That was point I was trying to make a few posts back. If they are 100% over, I bet the Industrial pump isn't keeping up or custom tuning is needed badly.
