- Joined
- May 22, 2011
- Messages
- 15,240
- Reaction score
- 1
looks and sounds awesome. im sure the tight housing helps a ton... might want a gate now though.
Watch the video, it show FRP. It maxed to 142mpa and fell from there.Is 100% over equal to Elites 110hp injectors? If so the stage two fuel system should hold 26,000 no problem. If that is what he has on the truck.
Heres craigs new setup Bullseye s475 batmowheel, 100% nozzles and II pump, the funny thing is this setup spools great with the .90 housing on it, vids to come
Are we talking spool up as good as the S366, spool up better than the S366, or spool up better than the S372 you have but not quite as good as the S366?
About the Back pressure, at idle its 120mpa so at full boost its at around 540-580 so you need to take away the 120 so in reality its only about 420-460mpa, im pretty sure they are equal to 110's, craig has the airdog with the elite add on
I dont wanna start anything about the percentages to elites injector sizes but from wat i heard 100% is bigger then 110s.
So......
